Been using Virtual DJ with no problems for a couple of years now. Just got a new laptop and everything worked great with the exception of songs randomly slowing down for a second (and then returning to the original pitch). Very strange. I'm using the latest version of VDJ with (2) iCDX's and a Maya44 USB soundcard. Any suggestions on how to fix this?
geposted Thu 21 Jun 07 @ 6:15 am
Try to use it without iCDX to see if it is there a problem.
geposted Thu 21 Jun 07 @ 12:10 pm
I have had the same problem with cue. i use the dmc2. every once in a while the tracks will slow down or speed up. it will not stop doing so until i reboot the computer.
geposted Fri 22 Jun 07 @ 7:56 pm
Sheesh, not another bug?
geposted Sat 23 Jun 07 @ 9:02 am
bryant im sorry to see you are having issues but that doesnt justify you posting that on every last topic.
no offence , but if you cant add somthing constuctive please dont post.
geposted Sun 24 Jun 07 @ 1:07 am
would you mind posting your current performance options and spec
geposted Sun 24 Jun 07 @ 1:08 am
Sorry, sky, I'm not really having a "lot" of issues, but just a few that seem to appear on here over and over
that I know are things that are in the program and not always a system fault.
I just felt the the Dev team or the programmers don't seem to be addressing all these same issues that crop up here, w/o resolution.
geposted Sun 24 Jun 07 @ 10:24 am
they are currently working their arses off to make a update for many things, so dont worry about that
geposted Sun 24 Jun 07 @ 11:53 am
Just my thoughts here.
Sky is correct, team is always trying to correct problems. I think the team has gone out of their way to try and accomodate each persons needs. True there are some glitches, but let's not forget the team is working on more than one problem. I am sure this is quite difficult to incorporate all the different bells & whistles some folks want or need.
geposted Sun 24 Jun 07 @ 1:45 pm
I had this problem when I used a Herk DJ Control 1, I bought a BCD2000 and problem went away
geposted Tue 26 Jun 07 @ 7:59 am
