Forum: Old versions
Topic: Preview/PFL and large file load issue
1. If output is set to single output the right click Listen (preview) song does not work at all. Also the PFL doesn't work when in broadcast/record mode. Correct behaviour would be to send Master to broadcast/recording but still allow pre fader listen/monitoring through the single audio output. Practically this means that the single audio output is the headphone/monitor and the Master is *only* to the shoutcast broadcast/wav record. I use the asio4all and it doesn't allow selecting other than single output since I only have single stereo pair on laptop thus changing the configuration isn't possible.
2. Even after full analyze done before loading the file, mp3 files seem to be limited to roughly 4000 beats. eg. load 60 minute song and only 22 minutes can be played, trying to go further results the pointer going to start of the song. I was planning to throw in couple songs middle of existing mixed mp3 and found that I could not even seek to the point where the song was. Weirdly enough I've not had this issue before and it's only recently that I updated to 4.3 so it's probably new bug.
Both are high importance issues for me and would like see them fixed in next update.
geposted Sat 23 Jun 07 @ 2:29 pm
1.
what card do you use with asio for all?
asio for all is more of a hack than a full driver
have you tried it with just the cards drivers
2.
in options set max load to always
