im trying to record with virtual dj and wen i make a mix im trying to use the crossfader but still the other side comes out like i want it to b clear and i o9nli wanna hear it on head fones not wen i mix it and then u can still hear it even if deck a is playing wat im trying to say is wen im already mixing the deck a with b and the crossfader is all the way to the right and then i load up a song on deck a i and i start scratching on deck a u can hear in da mix like if the crossfader is still in the middle i need help trying to fix this i wanna make a good mix with my timcoded vinyl hope u guys can giv me a tip later
geposted Sun 24 Jun 07 @ 12:19 am
what is your pc spec and what version are you using?
geposted Sun 24 Jun 07 @ 12:56 am
nevermind the problem i fixed it already it was a wire that was not workin but yea i have a dell dimension 2400 and 2.79 ghz and windows xp
geposted Sun 24 Jun 07 @ 2:30 am
