Topic: samples/3rd channel
bogartPRO InfinityMember since 2004
When using a mixer, how can you have samples play on a 3rd channel?
IE: Deck A is channel 1 Deck B is channel 2. Thought I saw posts previous about this but can't seem to locate it.
geposted Sun 24 Jun 07 @ 1:20 pm
You need a 3 channel mixer (I assume you have one already)
If you are using a no input devices and just a controller, Then It's very easy.
soundcard set-up
Choose 3 channel external mixer.
choose channel selectons - front speakers - deck 1, rear speakers - deck 2, center/sub woofer - samples.
geposted Sun 24 Jun 07 @ 6:38 pm
More than 3 channels on mixer so that's ok.
I understand how to set sound card, as your instructions.
Have 2 lines out from sound card to mixer.( one to channel1 and one to channel2). So how do the samples play on channel 3?
Thanks
geposted Mon 25 Jun 07 @ 5:30 pm
DJ-ALFPRO InfinityModeratorMember since 2005
You need 6 channels sound card for that such as Sound Blaster Live 5.1 USB. Very cheap and very good ;)
geposted Mon 25 Jun 07 @ 5:45 pm
Thanks much.
geposted Tue 26 Jun 07 @ 7:35 pm
