How can I play with digital timecoded vinyls and analogue vinyls at the same time?
thanks
thanks
geposted Mon 25 Jun 07 @ 3:31 pm
you cant play 2 analog and 2 digital at the same time , but you can swap them
as in one tcv , or one analog
or two analog or two tcv
chose mixed mode on the sound config on 3.4 console edition
then to play a normal record , remove the tcv , and place your analog record on the tts , press the input selector buttons on the front of the console
that way when you move the crossfader from the mp3 , to the other deck the sound from the vinyl is played
geposted Mon 25 Jun 07 @ 3:39 pm
Thanks for answering.
Indeed, I would like to use my timecoded vinyls and still be able to mix them with my old records, but I'm using virtual dj pro 4.1 and I don't see the mix mode in the sound config.
geposted Tue 26 Jun 07 @ 1:38 pm
thats because its not in there
please get the latest demo , 4.1 has not been available for a very long time
and consult this
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
it is crutial you have a stable offical version for tcv to work
and consult this
geposted Tue 26 Jun 07 @ 2:02 pm
Tcvs only is working fine. So if I understand you correctly it is not possible to mix analog vinyls with tcvs using virtual dj pro 4.1?
geposted Tue 26 Jun 07 @ 4:59 pm
using ancient ilegal/ versions of the software will lead to all sorts of problems
best to remove it.
in the latest demo , or pro vdj it will work well
best to remove it.
geposted Tue 26 Jun 07 @ 6:22 pm
It is not an illegal copy but even if it were, the virtual dj console edition only let's you play with timecoded vinyls for 5 minutes! Or isn't that so?
I have also a second question and that is why virtual dj doesn't get a timecoded signal when playing timecoded cd's?
Thanks
Thanks
geposted Wed 27 Jun 07 @ 2:31 am
the pass trough feature sucks on the mk2
My main problem was that It doesn't have input vol control
and my numarks players had a very high output
might be different with records.
geposted Wed 27 Jun 07 @ 6:46 am
im sorry but you just told me your using 4.1
your only licenced to use 3.4
and shoulnt even have acess to full 4.1
im not telling you off or any thing like that its just that that versions screwy and can cause some major crazy issues with tcv
at the end of the day its your call..
hope to see you with us soon
Kind regards
Simon
Kind regards
Simon
geposted Wed 27 Jun 07 @ 10:01 am
Is it so that with Virtual DJC edition I can only play for 5 minutes with tcvs? Because if not, it is indeed better for me to use that version.
geposted Thu 28 Jun 07 @ 11:55 am
yes it is limited to 5 minutes to give you a taste
geposted Thu 28 Jun 07 @ 1:41 pm
I'd like the option of switchign between TCV and real vinyl.
I've got version 4.3. I can't find the input selector, looked on keyboard shortcuts to find a way of playing real vinyl. Can someone help. Is there a shortcut i can program on the keyboard, or a way of changing input from TCV to real vinyl.
Many Thanks
Many Thanks
geposted Fri 29 Jun 07 @ 11:16 am
the input selector is a feature of the mk2 only
and is on the console
as to the bypass mode it has been removed because it had a bug it may be reincorporated soon
it is nessary to use yspliters and an external mixer to my understanding at the moment
geposted Fri 29 Jun 07 @ 11:34 am
OK thanks,
i'll have a look at the ysplitter option
Cheers
Cheers
geposted Fri 29 Jun 07 @ 11:40 am
