Is it possible to set the Pitch Reset to smaller increments?
Right now they are set at .5 bpm. If they could be just a litter smaller say .2, they would go unnoticed by dancers. Right now at .5, a dancer can notice the change.
Thanks,
Sm57z
Thanks,
Sm57z
geposted Mon 25 Jun 07 @ 9:33 pm
Yes that is already possible by making your own keyboard shortcuts, or changing the current ones. If you set it to the lowest value you have to press 3 times to get an increment of 0.1.
Ewout
Ewout
geposted Tue 26 Jun 07 @ 10:16 am
I agree, the pitch reset should have more 'steps' by default.
geposted Tue 26 Jun 07 @ 8:12 pm
I think Sm57z is talking about the VDJ intern Command pitch_reset not pitch where you don't have any influence to the steps it makes and only have to press the defined shortcut for it one time.
If you use the command pitch you can although define the steps but you have to press
the defined key multiple until the pitch has reached his origin value.
I think pitch_reset use the same value/steps like the option auto pitch reset
So if i not totaly wrong, the Question should be:
Is it possible to change the value / steps that pitch_reset and/or auto pitch reset used?
As far as is known to me its not possible, perhaps there is way within the registry?
I hope to help and advance
geposted Tue 26 Jun 07 @ 11:34 pm
