hello,
i have recently purchased a hercules dj console mk2.
everything seemed to go just fine and then i noticed that sometimes the track halts for a second or slows down making the mix sound just awful. also another sighted symptom, which i think is related to the problem ,is flickering lights under the "audio source" buttons on both sides.
i would appriciate whatever help anyone can offer on the subject.
thanks a million.
ori.
thanks a million.
ori.
geposted Tue 26 Jun 07 @ 7:01 pm
What specification is your PC?
geposted Wed 27 Jun 07 @ 1:07 pm
what exactly do you wish to know?
what from the specifications is relevant?.
geposted Thu 28 Jun 07 @ 2:52 pm
Model ? Windows version ? Cpu ? Ram ?
geposted Thu 28 Jun 07 @ 3:31 pm
Well if you are using a Pentium 486 or P1 or P2 or P3 and 64MB of RAM then this will have a big bearing on how well the software operates.
I had being using a VAIO M1 with P4 2Ghz and 512 RAM running XP and got lots of blips. Now have a Vista enabled HP with Duo processors and 2GB of RAM and have 15 windows open the other night and was mixing and creating BEBO skins whilst browsing the net without any blips.
If you want help just give the answers and we can try and help. We won't poke fun at you if you only have as a ZX Spectrum (honestly)
geposted Fri 29 Jun 07 @ 9:38 am
