Forum: Old versions
Topic: extra audio plugs
I am a amateur dj... strongly thinky of switching gear to the mk2 hercules console...loks nice and simple less stuff to carry around... I often need a extra cd feed or other rca plug in feed. Can you connect extra inputs or only phono on this console., doesn't look to strongly built but all the feedback seems to be positive... i am just using virtual via laptop like the program....ifo is appreciated
geposted Tue 26 Jun 07 @ 11:59 pm
You can connect your cd player to the MK2.
just chck out a better site for the specs thanks... i already have virtualdj 4.2 can i use the mk2 with it or do i need to use the lesser version that comes with mk2
Yes, you can use 4.2 demo version (4.3 will be out soon ;) ) for 20 days or you can use 3.4.1 version (Home) which is coming with the MK2. You can also buy a Pro license with a discount if you have MK2 :)
Hope to see ya soon a Pro!
