Hello All,
I have a Windows XP SP2
Pentium D CPU 3.20GHz Intel
2G memory
NVIDA 512 Mo
Intel Sigmatel cardaudio onboard
SL1200 MK5 with timecodes VirtualDJ
Hercules MK2
External Mixer Denon and...
microKontrol KORG ( MIDI STUDIO CONTROLLER ) and i used it to make a short cut loop, gain, effect, sample and more...
So, now i have a problem... my computer detect sometime my Korg, sometime not! And each time i shut down my Korg my computer restart without any warning! A very quick blue screen appear but to quick to see what this message containt!
I have already download the last driver for my Korg. I also reinstall windows and the problem as come back!
Thanks for helps!
HappyGusto
2G memory
NVIDA 512 Mo
Hercules MK2
Thanks for helps!
HappyGusto
geposted Wed 27 Jun 07 @ 5:07 pm
Disable automatic restart
After this is done you can make a note of the bluescreen. If there are any driver details make a note of it, also copy down the STOP error code. It's most likely a driver conflict.
Quote :
1. Go to Start -> Control Panel -> System
2. Go to Advanced
3. Under the Startup and Recovery section, click Settings...
4. Under System Failure un-check "Automatically restart"
2. Go to Advanced
geposted Wed 27 Jun 07 @ 5:10 pm
Thanks you Andrew87, i appreciate your help!
geposted Thu 28 Jun 07 @ 2:39 pm
Ok Andrew87, it's a dpc problem... i don't know what it is but i will try to find out!
Happygusto
Happygusto
geposted Thu 28 Jun 07 @ 3:44 pm
