Total control trouble
OK guys I’m leaving for work in about an hour so let try to nock this out soon Please!
I just noticed that only when a song is playing, deck 1 deck 2 headphones, and I move any of the knobs, jogs or faders I hear a bad electrical sound that will last as long a I move the feature. Like knob turning up and down the noise continues with the movement and when I stop the movement the distortion stops. Doesn’t affect the music. If I turn the gain down the distortion goes away but no sound. Only when music is playing
Sounds like when u rub your hand across a balloon.
I changed usb cable and with and without power adapter is
geposted Fri 29 Jun 07 @ 10:22 pm
Its a sound card issue Paul..the TC has no sound input at all..check out your card and drivers...and your divx.
geposted Fri 29 Jun 07 @ 10:29 pm
I just hooked it to my laptop and it worked fine. I'm going to try using my usb sound card
geposted Fri 29 Jun 07 @ 10:34 pm
looks like that was it. freekin onboard ASUS card.
Thanks
geposted Fri 29 Jun 07 @ 10:54 pm
No problem Paul..glad to help.
geposted Fri 29 Jun 07 @ 11:08 pm
