Does anyone know of VDJ COMPATABLE visualizations that are similar to the shadow dancers?
Little cartoonish charaters dacing in time to the music would be cool as hell.
I've searched and I'm not sure what is compatable.
geposted Fri 29 Jun 07 @ 10:33 pm
you should be able to use the shadow dancers .......
geposted Sat 30 Jun 07 @ 1:12 am
Hmm, where do you get it, sounds good!
geposted Sat 30 Jun 07 @ 10:22 am
Hi, I thought that there wasn't any way that you could play a video file in the same way as the soniques, etc.
I wanted to do the same sort of thing (play clips from a visuals DVD when audio only was playing), the only way i found was to use an actual DVD player, then plug it into the computer using a usb video capture card (mine's made by "kworld"). The camera plugin recognises the capture card and can then be set to be activated whenever there is an mp3 being played.
As for other visualisations working in vdj, i think any "sonique"one should work, but pretty much all of the available ones were already in the "78 plugins" pack on the downloads page. Maybe there's a few lurking around that haven't been found before, but when i did a search a little while ago, I couldn't find much. (I think they're pretty much obsolete, there's other better ones now i think)
geposted Sat 30 Jun 07 @ 12:51 pm
