Forum: Old versions
Topic: No connection link
I just recently installed VDJ 4 and I go to open it and my computer is saying that there is no connection link from my computer. Has anyone ever had this issue or problem before? If so how do I correct it so I can use my VDJ. I need to start learning the program as the club I am going to be working uses VDJ, and I have been learning on Traktor 3.2 Any information would be greatly appreciated guys thanks.
P.S. Yes I am a noob at this, but the faster I can play with this program the better.
geposted Sat 30 Jun 07 @ 7:26 am
R u using the demo V4.2 or... Try use the official demo v4.2 n u should be fine:)
My DJ buddy burnt me a copy of the version he has and uses.
And I did try to download the Trial Version from here off the site and I got the same response.
Firstly it is illegal to share the version n license cant be transferable and secondly state down ur system spec, maybe somebody out there will help to sort it out
perhaps you should ask your dj buddy for support?
if you like the program please support its development
and please write your spec , i might be able to help you.
i hope to see you as a pro user soon
