Forum: Old versions
Topic: Stability of BCD3000
I have the BCD2000 and i had experienced a few stability problems. I have tried everything but i did'nt make it. I use it as a midi device. Now they say that BCD3000 has different chipset and it's more stable. Is it true?
So i need someone from the disapointed BCD2000 users who has tried the new BCD to tell me if the stability problem has been solved. I know it also has to do with the software (VirtualDJ) and how it handles it, but i think they could fix this.
Thank you
geposted Sat 30 Jun 07 @ 10:38 am
Behringer and instability? Sounds familiar ;)
Do yourself a favor people, go get Hercules MK2 or Numark Total Control ;)
hi guys...i am waiting for my bcd3000 (it will arrive on monday) and i will start working on something to make ti work on vdj, i have a universal mapper so i will try to make it right you know i will do my best so ...i just want to ask you guys to be patiente.....you will have notices of me ...:)
Dj Quintana
Good to know Dj Quintana ;)
You are on the mission :)
Hopefully the BCD3000 will be much better, having used the bcd2000 for half a year now, i can certainly say that the bcd2000 is a pice of junk, everything breaks down after some hard use!. I cannot emphasize enough how much more suited the xponent controller would be.
It seems that bcd3000 has many improvements, let's see what happens...
I have bought it a few days back and it works pretty well with VDJ, cept for the scratch-wheel, which is not scratching it properly (under my personal mapping). I am yet to download the mapper file provided here (will do as soon as megaupload allows me to or someone uploads it somewhere else)
BCD3000 is more stable with asio and wdm drivers, jogs don't work properly yet, I will go on mapping.
