it is the weirdest thing.
my hercules dj console mk2 does not like certain cd players.
same setup, different cd players.
denon dn-s3500 doesn't work with tccd.
pioneer 800 mk2 doesn't work with tccd.
and yet my $45 cd player with no scratching capability at all works just fine.
can't figure it out. any suggestions?
geposted Sun 01 Jul 07 @ 3:16 pm
try lowering the timecode volume by 13 db with a free audio editor such as audacity and burn a new disk
geposted Sun 01 Jul 07 @ 4:44 pm
hey,
got the software. no idea how to do that.
is there any way you can do it?
geposted Sun 01 Jul 07 @ 6:28 pm
use the reduction tool , select the entire mp3 and reduce it by 13db
geposted Sun 01 Jul 07 @ 6:38 pm
where is it located?
i looked through the effect menu item and could not find it.
geposted Sun 01 Jul 07 @ 7:34 pm
Just lower its peak level, you can use Sound Forge or Nero Wave Editor for that, quite simple.
geposted Sun 01 Jul 07 @ 7:42 pm
never mind: got it.
effect > amplify : -13.0dB
geposted Sun 01 Jul 07 @ 7:45 pm
it can't seem to save it.
file, export mp3
and yet, it remains the same.
has anyone does this before?
can anyone send it to me?
file, export mp3
geposted Sun 01 Jul 07 @ 8:06 pm
I will lower it for you, stay tuned.
geposted Sun 01 Jul 07 @ 8:24 pm
@djkz
I sent you lowered Timecode on PM, check it out:
http://www.virtualdj.com/pm/
Hope it will work now
geposted Sun 01 Jul 07 @ 9:16 pm
got it,
thanks,
thanks,
geposted Sun 01 Jul 07 @ 9:31 pm
DJ ALF,
Can you Send that lowered TC Track to me? I tried lowering it and It was not working.
Thanks
DJ Digital
Thanks
DJ Digital
geposted Mon 02 Jul 07 @ 1:34 pm
I sent you on PM ;)
geposted Mon 02 Jul 07 @ 7:01 pm
