Looking at XP10 but can i get it in the U.S. ? Does it work with video? If not, which controller does?
geposted Sun 01 Jul 07 @ 9:25 pm
XP10 is just a controller with built in sound card and it is a nice one ;)
For video you need good machine overall, CPU, Ram and Video card to be good. 7600GT or new 8600GT video cards are the best for the money right now.
geposted Sun 01 Jul 07 @ 9:28 pm
Got a good machine with an adequate card.
But I'd like a controller that will handle video and not just mp3. Will the controllers handle vids or just mp3? I've worked with VDJ trial and I was very impressed. So which controllers will work with video also. Thanks for the help.
geposted Mon 02 Jul 07 @ 1:39 am
Any controller as you can map the fader to fade video and use external mixer for audio, that is the best combination by me. Controllers are MIDI devices and you can set them up the way you want with Mapper. Virtual Dj and a good controller like Hercules MK2 or Numark Total Control is all you need for video.
geposted Mon 02 Jul 07 @ 2:06 am
