Forum: Old versions
Topic: Internal Database is corrupted
I'm getting this error at start up.
Uninstall and reinstall programs.
Still getting the error.
Can someone help
geposted Tue 03 Jul 07 @ 1:17 am
Go to Virtual Dj folder and remove this file:
Virtual DJ database (your XP account name).xml
then VDJ will make a new one, but this way you will lose all of your data, there is a repair tool called RunVDJ but it is for Pro license users only.
Thanks
it worked fine.
Glad I could help ;)
Backup that file often and if it happen again just overwrite it with the good one and you are ready to mix ;)
