Having a humming sound when I plug my mk2 into the pre amp.
can someone help.
can someone help.
geposted Tue 03 Jul 07 @ 3:23 am
Are you running off a laptop by any chance? If so, try disconnecting the power cord and run from batteries. If the humming stops when you do this, it's our old friend the ground loop. This can be fixed by disconnecting the earth pin on the mains plug (the cheapskate way), or by purchasing a ground loop isolator (the proper way). Hope this helps!
geposted Tue 03 Jul 07 @ 4:25 am
Yes i'm running from a laptop.
I disconnected the power the humming stoped.
I try to get a ground loop isolater to fix it.
thanks again.
thanks again.
geposted Tue 03 Jul 07 @ 4:31 am
http://www.guitarcenter.com/shop/product/buy_ebtech_hum_x_hum_exterminator?full_sku=150452
Worth every penny I have 2 and they work great
geposted Wed 04 Jul 07 @ 4:21 pm
