Forum: Old versions
Topic: One Turntable
Can someone please help. Im doing a show this weekend and i am stuck.
I want to use one turntable for my system and go back and forth between a and b can this be done.
If not why does it show use with one turntable in config.
Setup:
1 technic 1210
1 hercules mk2
hp laptop
pioneer djm-500
1 timecoded vinyl
someone please help!!!!
geposted Wed 04 Jul 07 @ 3:07 am
hey, if ur turntable is in line at the mk2, i dont think u could swap it tru deck a n b. example if it put on deck a, it will be locked to that position. As i myself use turntable too n it work that way. ICDX or XP10 can be swap deck if i not wrong:))
Single Time Code Vinil setup doesn't work with VDJ 4.3 & Hercules MK2, in the next VDJ release this BUG will be solved I hope.
With other sound card the single time code setup have no problem.
Nevertheless, it functions.
Use the "Clone Deck" function. Mix with your turntable. Then copy the song to the other side and move the crossfader to the cloned deck. that´s it :o)
I have found the little bug, single time on MK2 work only if time code signal comes in input 1-2, the input 3-4 can be used for second time code only if two time code are connected.
yeah, that was the set i been using:))but u cant swap the deck tho:( if using only one timecode by using the herc.
