Forum: Old versions
Topic: Won't rip last video track
Running latest version of cue & when using "Rip DVD" the last track reports error & does not rip. All other tracks rip ok it always the last track.
This is using diffrent manufacturs music DVDs & not just one type. I have seen on the forum this issue raised b4, but cant find fix...any ideas?
geposted Wed 04 Jul 07 @ 3:39 am
Maybe it's the DVD menu you are trying to rip - some tracks won't rip from a straight rip - the actual songs, yes - but, if you play a DVD in the normal way, you will find that there's an interactive menu which takes you to various parts of the DVD.
Never worked with music DVDs before - but, if they are similar to DVDs of movies and TV shows, one of the "tracks" (or several of them) are menus and sub-menus - or maybe interactive elements.
Thanks guys will use "vjripper" for my last tracks.
Just to let you no thou, when using cues included ripper - you put disc in and hit the "<>" button this populates the lists with all the track numbers on that DVD say 1 to 15 & ticks box next to it to confirm what tracts you want ripped. (or un tick not to) Ie there is no menu or title tracks etc just a list track numbers. It ripps all tracks but reports "error" on last track.
pps: It may help other to no that "Mixmash" disks are ok and rips the last track, it just seems to be "promo" only disks that produce this error.
Thanks again guys for your time & quick response.
