Hello Everybody,
I'm using the Hercules DJ Controller with Virtual DJ Pro 4
It seems that I'm not able to hear decks a or b on my headphones to cue.
has any had or currently having the same problem.
Thanks in advance.
DJ Mack
Thanks in advance.
DJ Mack
geposted Wed 04 Jul 07 @ 1:44 pm
it doesnt automaticaly prelisten to Deck A or B yet
you have to choose
headphones
4.1 card
1/2 MAIN 3/4 headphones
then set the Selector to A
and to listen to the deck you wish to press the PFL button for it or make ur self a keyboardshort cut.
you have to choose
headphones
4.1 card
geposted Wed 04 Jul 07 @ 2:31 pm
Thank you for your help.
I can hear out of deck a now, but when I switch to b, I still hear a.
I looked at page 6 of the manual to see if could find the pfl you spoke of, I couldn't find it.
How exactly do I set the Selector to A or B?
Thank in advance.
DJ Mack
Thank in advance.
DJ Mack
geposted Wed 04 Jul 07 @ 10:31 pm
PFL is on the main skins , just under the volume slider for each deck , you must keep the selector on a
and use the pfl buttons to choose decks
this should be changed soon.
geposted Thu 05 Jul 07 @ 11:07 am
Great,
Thank you so much for your assistance.
This works like a dream.
I seriously hope they add this feature to the video interface, as I plan to use it very soon on a gig.
Keep innovating!!
DJ Mack
Keep innovating!!
DJ Mack
geposted Thu 05 Jul 07 @ 2:43 pm
you can use keyboardshortcuts to change the preview deck too :)
have a look on options
geposted Fri 06 Jul 07 @ 12:15 am
