Right now I have all my songs under a folder called "Dj" and under that its organized by hip hop, house, hard, rnb, etc....
I don't wanna lose all my bpms and cues and shit, so how can I backup my database, and when I reformat, I can jsut take that folder and reload it onto the desktop, and be ready to go?
(When I say database, I don't mean the .mp3 files.... duh)
geposted Sat 07 Jul 07 @ 2:57 am
has been discussed many times, but anyway ...
go to C:\Program Files\VirtualDJ
look for VirtualDJ Database ("user name").xml
that's the database file
also backup your short cuts, if you made/changed any ....
shortcuts.xml
if you saved them under another name...
well, then that one ...
shortcuts.xml
geposted Sat 07 Jul 07 @ 5:21 am
that is correct
geposted Sat 07 Jul 07 @ 7:20 am
