Hey guys!
I'm pretty new with the digital setup and i need your help!
I want to get a digital set up but i DO NOT KNOW WHAT TO GET! If you can tell me what turn tables,mixer,soundcard to get for my setup to work with V-DJ on my laptop would be great!
thanks!
thanks!
geposted Sun 08 Jul 07 @ 2:00 pm
what type of dj are you
mobile , club , turntablist?
geposted Sun 08 Jul 07 @ 5:26 pm
Club, any link or help on the right setup would be good. Is the Senato any god?
geposted Sun 08 Jul 07 @ 6:30 pm
do you need stratch?
could you tell me abit about what you hope to achive and i will recommend somthing for your needs
we dont support sterato here , its a different product.
geposted Sun 08 Jul 07 @ 7:27 pm
No, no scratching just mixing and playing. I just need to know a simple setup and simples gears that is available world wide (I live in New Zealand)
Price is not a prob and would like to keep the budget low
so any help would be great.
geposted Sun 08 Jul 07 @ 7:31 pm
maybe u could get the herc MK2 for a start:))
geposted Sun 08 Jul 07 @ 8:56 pm
If you're a club DJ, you're used to Technics 1210 Mk2? Or maybe the Pioneer CDJ-1000 Mk3? Would you like to extend your ability using these club formats, e.g. by using Timecoded Vinyl/CD. Or would you prefer to escape what you know and use external hardware controllers.
geposted Sun 08 Jul 07 @ 9:04 pm
the mk2 dj console is a good bet to start , it is a good controler and soundcard and supports the timecoded vinyl system mentioned above
http://www.virtualdj.com/products/timecode/
you aslo get virtual dj console edition to get you started :)
geposted Tue 10 Jul 07 @ 2:40 am
