Just wondering after i buy vdj that is
looking through the effects
how come tape echo effect isnt there
its there in the numark dxm 06 and dxm 09 mixer
its a great effect for transition
downloaded the demo version and been using it since 2 weeks
absolutely love it
purchased 1 gb ram and 7200 rpm hd on intel pentium 4 desktop
running well
now im planning on buying a mixer or an external conttroller along with the full version of vdj
considering buying the bcd2000 or numark dxm-06
The numark mixer will be connected to my current integrated soundmax soundcard(the crappy default one) and will be working with computer speakers
The behringer bcd2000 will it confugure k? and is the behringer stable not plastic feel?
Both are approx the same price..cant afford a maya or m audio now so will connect numark to integrated soundmax card
Q1.which one is more stable in the long run?
Q2. Also how will i beatmatch with the mixer dxm-06 connected on vdj..I will have to use a mouse and keyboard wont that be tough..isnt the bcd better since it has pitch control?
very very confused..which one should i go for
pl suggest pros and cons
absolutely love it
running well
geposted Tue 10 Jul 07 @ 6:04 pm
