Forum: Old versions
Topic: Hercules Installation?
I am trying to load the Hercules drivers using a file called 2007_CMK2_2.exe. I am doing this before installing CUE. However, I keep getting a message during installaton from the Wizard saying:
The hardware was not installed because the wizard cannot find the necessary software.
Is there a special trick to installing this? Do I need to install CUE first?
geposted Wed 11 Jul 07 @ 2:06 am
hey cheech, I installed numark que first. then I hooked up the Hercules, then installed the software and everything worked fine.
dont forget to add your serials guys to get pro benifts :)
