Ok, so I'm new to the whole DJ and audio thing in general and was looking to create a small beginner setup.
I ran into some snags in that I have Vista 64-bit, so my options have become fairly limited and I've narrowed my sights down to the FA-66 and FA-101.
Now from the looks of it the FA-66 only has 1 RCA input (red/white), leading me to believe that only a single turntable can be hooked up to this card. Is this correct?
Sorry, this probably seems like a pretty noobish question...but audio hookup isn't my strong suite at the moment. :-)
geposted Sat 14 Jul 07 @ 6:40 pm
I use the EDIROL FA-66 sound card with my Vestax vci-100 and mixvibes pro 6
I have also tested it with virtual dj timecode {up-date 3.4}
it's a good sound card
edirol fa-66 is a 4 mono in-put, 4 mono out-put...so you can run 2 turntables at the same time
1 turntable go's in the front & 1 turntable go's in the back..all the outputs are in the back
you need to get 6 RCA to mono jack adaptors
If you are running 2 tec 1200 turntables you might have to get 2 pre-amps
I no there are Vista driver's ...but I don't no if thay are 32 or 64 bit
I'm sill running XP PRO SP2
geposted Sat 21 Jul 07 @ 7:09 pm
