Forum: Old versions
Topic: 100% CPU Usage
Hello Friends
I've got a very big problem with last VDJ version (clear install, no update).
When I'm using VDJ for a long time song analysis begins to go slower and slower and my CPU usage reaches 100%
I've got a very big VDJ Database, lot of song on my hard disk... Could be a Database size problem?
Thanks
geposted Sun 15 Jul 07 @ 8:00 pm
whats your spec?
what version did you use before?
I see you have Hercules MK2, do you use Cel's, mapper? You should use 2007 drivers for it to run properly.
Hi, again.
I'm using a PIV 1.8, 1Gb RAM, 400Gb HDD and ASROCK P4VM890 Motherboard (It's the only new hardware on my configuration since version 3.x)
I'm working on Weedding (no laugh ;) ) and past year I was using version 3. Now I'm change may Motherboard and VDJ version.
I'm gonna install version 3.x and Itold you later.
Thanks!
About Hercules I'm using latest drivers.
Also after upgrading, my CPU usage reaches 100% When I'm using VDJ for a long time song analysis begins to go slower . anybody knows why?
how much ram do you have?
yeah how much ram n how many processes activity in ur background?
