Forum: Old versions
Topic: Quicktime 7 update.
QuickTime 7.2 addresses critical security issues and delivers:
- Support for full screen viewing in QuickTime Player
- Updates to the H.264 codec
- Numerous bug fixes
This release is recommended for all QuickTime 7 users.
Important Notice to QuickTime Pro Users
QuickTime 7 will disable the QuickTime Pro functionality in prior versions of QuickTime, such as QuickTime 5 or QuickTime 6. If you proceed with this installation, you must purchase a new QuickTime 7 Pro key to regain QuickTime Pro functionality. After installation, visit www.apple.com/quicktime to purchase a QuickTime 7 Pro key.
basicaly it has a better Codec , and playback than previous versions and adds alot of new neat features if u happen to buy pro , if you have pro it only costs 20$ to upgrade
At any rate even the free version , should boost your video performance while using osx so worth the update.
geposted Sun 15 Jul 07 @ 11:13 pm
