Can I get advice on this laptop configuration?
Is possible to run shared graphic memory for VIDEO MIXING.
Processor AMD Turion 64 X2 TL-60 2,0 GHz 2 x 512 KB L2 cache, 667 FSB
Screen 15,4" WSXGA+ WVA anti-glare LCD Resolution 1680x1050
RAM 2 x 1024MB DDR2 667 MHz max 4GB, dual channel memory
HDD 160 GB, S ATA HDD 5400 rpm
Graphic ATI® Mobility™ Radeon™ X1250, Microsoft DirectX 9 capable up to 512 MB shared
geposted Wed 18 Jul 07 @ 11:08 pm
Barely I think, why not get a model with dedicated video memory?
geposted Thu 19 Jul 07 @ 2:08 am
How do u know if the laptop had dedicated memory or not?
geposted Mon 10 Sep 07 @ 8:30 pm
That laptop has dedicated memory, it just says 512 SHARED because the graphics card probably only has 256 onboard, and it borrows the other 256 from the system. The best thing you can do is look around and see if it can play newer games. If it can, it will be fine.
Edit: Tell us what laptop you're looking at because I don't want to be wrong, and then you buy it and it can't work.
geposted Tue 11 Sep 07 @ 4:29 am
I'd recommend a ATI X1600 card, with 256 dedicated ddr2 ram
geposted Tue 11 Sep 07 @ 8:24 am
