Forum: Old versions
Topic: BCD 2000 with VDJ working great Here's how
Hey just to let everybody know that the Bcd 200 and vdj seams to be working fine (except the no mike think. Here is my set up and What I did.
Found this list of tweaks on the net. Not sure if works for everybody but it worked for me!
All these settings were find on different internet pages and they actually help to run VDJ faster, but you set
all these settings on your own and nobody is responsible if these settings will damage your system.
1. Processor scheduling should be set to Programs and not to background services. Start > Settings > Control
Panel > System > Advanced > Performance Settings > Advanced Tab > Programs.
2. Visual effects should be set to a minimum. Start > Settings > Control Panel > System > Advanced > Performance
Settings > Visual Effects Tab > Adjust for best performance.
3. Switch Off Desktop Background Image Right Click Desktop > Properties > Desktop Tab > Background
None.
4. Disable Screen Saver Right Click Desktop > Properties > Screen Saver > None.
5. Disable Fast User Switching Start > Settings > Control Panel > User Accounts > Change the way users log
on or off > Untick Use Fast User Switching.
6. Switch Off Power Schemes Start > Settings > Control Panel > Power Options > Always On > Turn off
monitor and turn off hard discs to Never.
7. Switch Off Hibernation Start > Settings > Control Panel > Power Options > Hibernate > Untick Hibernation.
8. Activate DMA on Hard Discs/CD ROMS Start > Settings > Control Panel > System > Hardware > Device
Manager > IDE ATA/ATAPI Controllers > Right Click Primary IDE channel and Secondary IDE channel >
Properties > Advanced Settings Tab > Transfer Mode to "DMA if available" for both devices.
9. Disable System Sounds Start > Settings > Control Panel > Sounds and Audio Devices > Sounds Tab >
Sound Scheme to None.
10. Do Not Map Through Soundcard Start > Settings > Control Panel > Sounds and Audio Devices > Hardware
Tab > (highlight your soundcard from the list) > Properties > Audio Devices > (highlight your soundcard
from the list) > Properties, and check the "Do not map through this device" checkbox.
11. Disable System Restore Start > Settings > Control Panel> System > System Restore Tab. Tick the "Turn
off System Restore on all Drives".
12. Disable Automatic Updates Start > Settings > Control Panel> System > Automatic Updates > Turn off
automatic updating. I want to update my computer manually.
13. Startup and Recovery Options Start > Settings > Control Panel> System > Advanced > Startup and Recovery
Settings > Untick Automatically Restart.
14. Disable Error Reporting Start > Settings > Control Panel> System > Advanced > Error Reporting > Disable
Error Reporting.
15. Disable Remote Assistance Start > Settings > Control Panel> System > Remote > Untick Allow remote
assistance invitations to be sent from this computer.
16. Fix Swap File (Virtual Memory) Start > Settings > Control Panel > System > Advanced > Performance Settings
> Advanced > Virtual Memory Change > Custom Size. Set initial and maximum size to the same value.
17. Speed Up Menus Start > Run > Regedit > HKEY_CURRENT_USER > Control Panel > Desktop Folder. Set
MenuShowDelay to 1.
18. Disable Offline Files Start > Settings > Control Panel > Folder Options > Offline Files Untick "Enable Offline
Files".
19. Disable Remote Desktop Start > Settings > Control Panel > System > Remote > Untick "Allow users to connect
remotely to this computer".
20. Disable Internet Synchronise Time Start > Settings > Control Panel > Date and Time > Internet Time > Untick
"Automatically synchronize with internet time server".
21. Disable Hide Inactive Icons Start > Settings > Taskbar and Start Menu > Taskbar TAB > Uncheck "Hide Inactive
Icons".
22. Disable Automatic Desktop Cleanup Wizard Start > Settings > Control Panel > Display > Desktop > Customise
Desktop > Untick "Run Desktop Cleanup Wizard every 60 days".
23. Make sure the NTFS Last Access Time Logging (NTFS File Systems Only) is enabled. Start > Run > regedit
> HKEY_LOCAL_MACHINE > System > CurrentControlSet > Control > Filesystem. Add a new DWORD
value - "NtfsDisableLastAccessUpdate" and set value to 1.
24. Disable Notification Area Balloon Tips Start > Run > regedit > HKEY_CURRENT_USER > Software >
Microsoft > Windows > CurrentVersion > Explorer > Advanced. Create a new DWORD value called Enable-
BalloonTips and set to 0.
25. Disable CDROM Autoplay To Disable CD Autoplay in Windows XP Pro -- [1] Start/Run/GPEDIT.MSC --
[2] Computer Configuration/Administrative Templates/System. -- [3] Locate the entry for Turn Off Autoplay
and modify(enable). Start > Run > regedit > HKEY_LOCAL_MACHINE > System > CurrentControlSet > Services
> Cdrom. Set autorun to 0.
26. Disable Disc Indexing Service Right Click Start > Explorer > Right Click Each Disc > Properties > Untick
"Allow Indexing Service to index this disc for fast file searching".
27. Delete unused icons on your desktop.
28. Make sure you always have empty Trash.
29. Close all unused programs running in background and located in System Tray.
30. Uninstall all unused programs and delete their folders after uninstall.
31. Do the Defragmentation of your disks at least once a month.
32. Do not put laptops to sleep, rather completely turn them off.
down load and installed the plug in and followerd the instructions in the manual for performance and sound cards. http://www.virtualdj.com/addons/tools.html
and the onlything that was missing in that manual was that the bcd panel needs to be set to b dj and not advanced. And for me the Slider on the bcd controol panel is set to 12 milla seconds.
After all this i still had problems with it freezing i then disabled the lan and wireless lan. And disabled antivirus.
Now it has run for 12 hrs with out a crash. thats with me djing and switching to auto dj and then a bit more of me playing around.
Here is my laptop specs.
Gateway MT6451 Notebook PC - AMD Turion 64 X2 TL-50 1.6GHz, 802.11g Wireless, 1GB DDR2, 120GB HDD, Dual Layer DVD RW, 15.4" WXGA, Windows xp 599.00 Canadian at TigerDirect.com
Not sure if this is good enough for Video on not.
Hope this helps somebody.
I have chosen to have a small mini mixer for my system to go into bevcause i need a mike, but i also want to be able to have a mixer to put a cd player on, should i have a complete windows melt down. All Midi sound cand mixers like the Bcd2000 will not function as a mixer at all if you loose your system.
DJ PM
geposted Sun 22 Jul 07 @ 1:14 am
Very Comprehenceive.
Good work.
Well done i have been using BCD2000 and it has been going ok. Followed your tweaks and i can say i do notice the difference. Am running VDJ 4.3 on an IBM Thinkpad T42 1gb Ram 2 x 80Gb Hd's, and performance up by about 15%. Once again good find
Should be sticky for a while ;)
Great topic!
