Hi all,
i`m new to the "family", just bought VDJ Prof. today and i`m very happy with it, works perfect with my M-Audio components. I tested a lot of DJ software before and i found out that VDJ is running great using TCV and i can run it on Windows Vista without any problems since a friend of my is using the Numark product (it`s 1:1 the same i think ?)
So if there`s anyone who thinks about buying the M-Audio interface: I can highly recommend it, easy install, great sound quality and i like the way of the audio routing and with VDJ + TCVs it´s getting even better :-)
Thx @ Atomix for such a great program, it made my decision to change to digital media a lot easier !
Edit: Is there any manual that explains what the difference between the "Smart / Absolute / ..." TCV setting is ? I checked the latest V4 manual but i can`t find anything about those drop down boxes.
//Ciacomix
Digitally Imported Radio (www.di.fm)
//Ciacomix
geposted Sun 22 Jul 07 @ 9:12 am
Hi Ciacomix,
we are happy that you'fe found this proggie as the best DJ software ;) Yes, it's the same as Cue, just changes the brand name and skin!
For explaining the difference between modes, you can watch this review of Numark Virtual Vinyl, there's all the information you need:
geposted Sun 22 Jul 07 @ 12:55 pm
