Forum: Old versions
Topic: URGENT!! Windows 2000 error, please help ASAP!
hey everyone, just got virtual DJ and when i try and start it i keep on getting some error messages, the one i'm getting at the moment is 'The dynamic link libraryd3d9.dll could not be found in the specified path C:\Program Files\VirtualDJ;.;C:\WINNT\system32;C:\WINNT\system;C:\WINNT;NC:\WINNT\system32;C:\WINNT;C:\WINNT\system32\Wbem.'
PLEASE HELP, I NEED VIRTUAL DJ FOR A SET TONIGHT!!!
geposted Sun 22 Jul 07 @ 11:08 pm
Are you using a cracked copy?
try a reinstall , this is not an ideal os for virtual dj 2000 was designed as a server
im not using a crack copy, i've just got the demo from this site! i've also tried download the new directx but that made no difference!
Ok, can you try to use XP instead? I am not sure how VDJ performs on Win2000 but it should work.
