using 'Numark Cue' software then use 2 soundcards,
1st sound card is extenal soundcard then set it up as Master.
2nd soundcard is internal soundcard set it up as a Cue to
listen from headphone....
but a sound from headphone is delay diferent from
a sound that you hear from Master,
Can i set Numark Cue software for Cue and Master
make a sound come at the same time??
geposted Mon 23 Jul 07 @ 10:56 am
Different soundcards have different latencies and hardware.
Try a different soundcard, or for most accurate performance use ONE soundcard.
To prelisten at one soundcard, you need a 4.1 or 5.1 soundcard (surround).
When using 2 cards, if one is PCI and the other USB, there might be a slight delay for the USB card compared to the PCI. Because PCI processes the sound a bit faster
geposted Mon 23 Jul 07 @ 11:16 am
can you suggest me? what model?
I want to use external soundcard.
geposted Mon 23 Jul 07 @ 12:45 pm
Get a USB soundblaster surround card .. such as Soundblaster Live USB.
(or any other known brand usb surround card. They all work)
Or if you also need a controller, get the Hercules MK2 controller with surround card built in.
geposted Mon 23 Jul 07 @ 1:47 pm
Please register it so we can all see the way cool CUE logo...:>)
geposted Mon 23 Jul 07 @ 9:37 pm
