I dont know whether to buy 2 of the numark cdx or the icdx. I notice in the remote control config there is only support for the icdx, will the cdx operate the same way? I plan on using the 5000FX mixer also.
It seems the icdx is better for loops and the cdx better for scratching?
geposted Tue 24 Jul 07 @ 1:06 pm
You are right, iCDX is better as it is a native MIDI controller while CDX is just a CD/Mp3 player and you must use Timecode CD with CDX.
CDX is better for scratching since it has real vinyl and it is motorized, like you are using a real turntable.
iCDX is CD/DVD audio media player which means you can use Mp3 files as a backup, and use it as a MIDI controller only for VDJ decks.
geposted Tue 24 Jul 07 @ 5:11 pm
Is the cdx likely to have midi support in 4.4 or is that not being looked at.
geposted Tue 24 Jul 07 @ 5:56 pm
Grug the CDX is not midi compatible, so mapping it would be futile. Grab the iCDX, I use two and love em. Look in my blog for a picture of them.
geposted Tue 24 Jul 07 @ 7:10 pm
Righto! Thanks for the info..two icdx's soon heading my way. Cheers
geposted Wed 25 Jul 07 @ 1:26 am
King of Jungle Only Here To Help! (George of the Jungle)....:-)
geposted Wed 25 Jul 07 @ 3:52 am
Go get em Grug ;)
Have a nice mix :)
Have a nice mix :)
geposted Wed 25 Jul 07 @ 3:59 pm
Actually just one more question about having 2 icdx... how do they both work together, eg how does VDJ know that you have two connected. Do I have to use a special VDJ mode like multi-instance, multi-skin or something.
geposted Wed 25 Jul 07 @ 4:24 pm
VDJ see automatic if 2 iCDX are connetcted and with eject button you can invert Deck 1 and 2, don't worry, this software is not stupid ;)
geposted Wed 25 Jul 07 @ 7:41 pm
LOL Cioce, it sure not ;)
geposted Wed 25 Jul 07 @ 9:22 pm
