Forum: Old versions
Topic: Automix for a Wedding
I have a wedding coming up this weekend, I have been playing with the "Automix" feature and desperatly trying to get it so the cue points are not half way into the next song.......
No matter what I try, and thats about everything, it just wont do it......is this a software issue?
My computer works great with TCV, video and everything else I put VDJ through the test.......the simple thing "Automix" doesnt work right......
HELP!
geposted Wed 25 Jul 07 @ 7:30 pm
Set fade to Zero.
And auto cue off.
As well as auto bpm off, if you dont want beatmixing
(probably not wanted at a wedding)
ok, will do.....I'll keep messing with it, I may have to do this manually for the weddding.
The settings that I use and work well for exactly what you are doing are as follows:
Crossfader - Smooth
Force Fade - Enabled
Fade Length - 3.0s
Hope this helps
Chansin is correct about setting up songs for auto mixing at dinner ...
Crossfader - Smooth
Fade Length - 3.0s
But also make sure "Auto Cue" is disabled. When enabled or on "Always" it's pushing to the first beat or cue point, that's why you have the jumps.
But there will lots of silences for those songs that have LONG quite intros or outros.
Is there a way to get the best of both worlds here. Will the new 4.4 have this in it.
that y i still use the cues.. :) to shorten the silence period..n it werk, same as playing via windows media player.
maybe ;)
SpinnaJ, but do you have to set the "edit automix" for every song you play or just those first two?
I have found that the settings I recommended work well with almost all dinner & background music. I would suggest just setting up a trial run and see how it works. Try the songs that you are most worried about.
NOt for every song only those 2:).it werks..
