Forum: Old versions
Topic: trial problem
I just downloaded the trail version. when its down i click on the virtual dj icon. it asks what skin i want to use, then it says its checking for updates. After that nothing shows up. What am I doing wrong?
geposted Mon 30 Jul 07 @ 3:12 am
Can you not cancel that?
You can then set the config to "Not check for updates"
Do you use any unofficial version b4 this?
try reinstalled the trial again..
is the config in the software?, because i cant get into it.
I thought it had a cancel button. Then the software opens
