Topic: EFFFECTS ON MIC? MK2
Is it possible? Reason I am asking is my board took a dump and my backup has no effects on it. I need to be able to add echo to my microphone. If I can't do it through the MK2, is there another way to get effects on the mic short of buying a processor or new board?
geposted Wed 01 Aug 07 @ 5:21 am
Doh.... I assume this means no eh?
geposted Sat 04 Aug 07 @ 8:08 am
Sorry, there is no way to process effects on mic ...
At least not yet.
Currently VDJ uses Windows mic setting, so VDJ dont process the mic input at all, Windows does.
So in theory, you could find another Windows software that would add DSP effect to the mic in, at your soundcard, but I dont know of any at the top of my head...
If you search google maybe you can find one, or a VST effect for mic inputs (works inside VDJ)
geposted Sat 04 Aug 07 @ 10:00 am
sbangsPRO InfinityMember since 2004
to make matters even more confusing the mk2 dj consoles mic is actualy more of a line in
geposted Sat 04 Aug 07 @ 12:25 pm
Yes and the Mic Output is very quiet.
I've always found i've needed to have the volume on the Mk2 down to about 40% on each deck, than have the mic volume right up to the max otherwise you just can't hear it!
geposted Sat 04 Aug 07 @ 6:16 pm
