Forum: Old versions
Topic: xp10 jogwhell sensitivity
i would like to know whether i can adjust the sensitivity of XP10 in
VDJ since i find it too sensitive compared to eks software which is supplied with xp10's
regards
mike
geposted Wed 01 Aug 07 @ 8:55 am
You can change its sensitivity via mapper or built in inside MIDI shortcuts.
thanks a lot for the response ....
so in mapper which values do i change in order to make it less sensitive ?
regards
mike
