Forum: Old versions
Topic: Deciding to buy VirtualDj
Hey I'm deciding to buy VirtualDj for MAC. But first I want to know something. I have a M-Audio Quattro USB sondcard and a Mac Book Pro. The drivers from 10.4.6 to 10.4.10 doesn't works actually (because I habe tested in other friend VirtualDJ).
So is possible to make it work with this soundcard, for example with lowers version of the driver like the 10.4.5 or is impossible at the moment to do that and I would have to setup Windows Xp on my mac with BootCamp to put this program on it or Djdecks.
Also I Have 2 FS Code Vynil for ude with them.
I wait your answes and thanks for all.
geposted Thu 02 Aug 07 @ 4:30 pm
Well...Currently the only soundcard that can be used with Timecode is the Numark Virtual Vinyl Box (VDJ Mac). If you want to use your soundcard you would have to set up Bootcamp and Windows or wait for the 'upcoming' update for Mac.
when it will be available?
??? There is no information on the next release. Myself as well as pretty much every Mac user is waiting, patiently as possible. Im sure they want to iron out the kinks before releasing a substandard update.
Hold tight!
You need not wait for next release available, as u can buy the pro version now n get the updates for free later when its time.. :) Still worth it:)
http://www.virtualdj.com/purchase/
