I Had Everythang Working Fine... Than All Of A Sudden Whenever I Start Up VDJ It Gives Me An Error Message Saying "ASIO Sound Drive Error" (Or Somthing Like That)
I Had This Problem Before But I Forgot How I Fixxed It!!!
I Tryed Uninstalling Tha BCD Drivers And Reinstalling Them And That Dident Work...
When I Start Up VDJ All The BCD Controls Function Except "Play/Pause"
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Also Once I Get This Fixed I Want To Hook Up One Time Coded Vinyl Threw BCD.....
I Know How To Hook All Tha Hardware Up I Just Dont Know All The Configurations
Can Someone Help Me Wih That? And/Or Point Me To Somewhere That Can Help?
Thanks
Thanks
geposted Thu 02 Aug 07 @ 9:40 pm
Which version do you use? What is your PC specs?
geposted Fri 03 Aug 07 @ 2:04 am
Its Version 4.2
And I Got A Toshiba Satellite Laptop (Im Not Sure Of My RAM And Memory)
geposted Fri 03 Aug 07 @ 2:40 am
Windows Vista (But I Had This Problem On XP Also)
Im Looking For MapleVMC (I Forgot What That Did But I Rember I Had It When I Had XP)
geposted Fri 03 Aug 07 @ 3:02 am
To All You People Thea Already Read This Thanks For Nothing!!!!!
I Got I Working Perfect!!!
geposted Fri 03 Aug 07 @ 3:18 am
Glad to here its working - how about registering your serial -- http://www.virtualdj.com/fusers/modifuser.html and upgrading to v4.3
[cracked version most likely]
geposted Fri 03 Aug 07 @ 3:46 am
you need to make sure the BCD2000 is switched on first before you launch VDJ4.xxx
geposted Fri 03 Aug 07 @ 1:11 pm
If you get a asio sound card error (witch you
might) Do the following to fix it.
4) Leave VDJ open. In your system tray or quick launch toolbar (on the bottom right of your start bar),
you will see a small blue box. Double click on it, on the right you will notice a setting for advanced or
b-dj set it to advanced and then set it back to b-dj and then close the box. Close Vdj and re open it,
there should be no error now.
geposted Sat 08 Sep 07 @ 5:09 am
