Forum: Old versions
Topic: Low output with MAYA44USB
I have recently bought the MAYA44 USB and Timecode vinyl. I have managed to set up so everything works but I am getting a very low output from the sound card to my mixer. I have changed the ASIO settings to full. I have to turn up the gains on VirtualDJ but even with this it is still low and starts to distort. Any advice
geposted Fri 03 Aug 07 @ 12:17 pm
Enter you serial please - http://www.virtualdj.com/fusers/modifuser.html
Are you running the MAYA Control Panel?
MUTE the MONITOR Channels 1- 4
OUTPUT should be at 95%
INPUT - vary depending on the timecode device's output quality.
Other than that you should be fine?
