Forum: Old versions
Topic: Constant Crashing
I just installed Virtual DJ today on my PC, and the program will not run for more then about 5 minutes without freezing up completely... I tried uninstalling and reinstalling but didnt help at all... please help beginning to get frustrated..
geposted Sat 04 Aug 07 @ 3:51 am
Dj console version with hercules?
Check if you have any serious hardware conflicts, check the IRQ layout at your PC
click here for a guide to check for irqs
provided by help with pcs.com
If you are using the MK2 controller make sure when you uninstall you delete it from the hardware settings in control panel also.
Cab you post the spec of your PC please, OS etc.
If still not work out, do a clean OS install.. :)
Cheers
