Is there a utility or is someone working on an improved ato2vdj utility. Manually entering the BPM's for 500 or more songs can really drive you up the wall.The current ato2vdj is not of much help either.
geposted Thu 10 Jul 03 @ 6:28 am
It might be possible to do a util that requires you to analyze your songs in VDJ first, and then read the atomixmp3 internal database BPM's and if the BPM in atomixmp3 was clearly different (like more than 20% or something), then it would overwrite the BPM in VDJ's database. This would probably allow to convert most of the manually fixed bpm's back, incase VDJ has detected them wrong.
geposted Thu 10 Jul 03 @ 7:24 am
"Clearly diferent" is not enough. If the values are not the same that one of them is wrong, and if BPM is wrong, beatbaching just wont do.
geposted Thu 10 Jul 03 @ 8:21 am
