Forum: Old versions
Topic: multiple audio channel from VOB file
Hi,
I have a VOB file (karaoke ripped from DVD) with multiple audio channels, is it possible to switch them within VDJ ?
geposted Mon 06 Aug 07 @ 6:13 pm
no... sorry.
When you rip the vobs, please choose to rip with Windows PCM Wave, or MP3 audio. Stereo.
Haali Media Splitter may be able to do it if you use Windows' DirectShow decoder vs VirtualDJ's in the software. Doing so is probably asking for trouble though.
True, good point.
you migh be able to, if you use Windows Media Player as decoder in VDJ, and specially so if you use Ffdshow as audio codec plugin for WMP. Pretty easy to change things with Ffdshow ... Or other codec (not familiar with the one Andrew mentioned, but sounds like it does the same)
can you please show me how to do this please
I was able to to into config and change VOB to Windows Media Player decoder, but dont know how to toggle the audio when playing
