Topic: Bussing sound on one channel laptop (XP).
tiger1PRO InfinityMember since 2006
Hi guys, i have a question. This never used to happen before, but after recently reconnecting my maya, it has started. I'm using TCV + maya usb 44 + external mixer. When i play TCV and move the cross fader on the mixer to the left i can here a buzzing sound. its like the buzzing sound of the vinyl (that you can hear directly from the vinyl) but it is coming through the speakers. If i move the crossfader on the mixer to the right, there is no buzzing or interference through the speakers. I don't think its anything to do with the left deck, because if i only play the right deck and move the crossfader to the left, the interference still comes through. i tired with real vinyl and there has been no problem. Any ideas anyone?
Thanks
geposted Tue 07 Aug 07 @ 12:31 am
sbangsPRO InfinityMember since 2004
how are you grounding your setup?
sounds like feedback
geposted Tue 07 Aug 07 @ 2:03 am
Just the normal way. I've attached the grounding wires from the turntables to the back if the mixer. It's wired becasue the setup hasn't changed, and this never used to be an issue. I'll have a look see if grounding is an issue.
Cheers
geposted Tue 07 Aug 07 @ 2:42 pm
