Forum: Old versions
Topic: is virtualdj 3 vista compatible (yes)
geposted Tue 07 Aug 07 @ 1:49 am
yes you can download the vista update for mk2 from your download center ;)
but if i buy this cd, it looks like it wont install in the 1st place in my computer, let alone update it... do u see what i mean>?
i mean like how can i update it if i cant have the program installed in the 1st place?
You can download the full Vista VDJ 3.4 from this site.
It works a treat. And ignore the review on that page that says you can't lock out the jog wheels as I always disable mine
it works now, thank you so much man....
