hi, i am trying to figure out if this version of the mk2 console plus the virtualdj 3 is vista compatible before i buy it, THANK YOU GUYZ!!!
http://www.guitarcenter.com/shop/product/buy_hercules_dj_console_mk2_dual_deck_dj_mixer?full_sku=103532479
geposted Tue 07 Aug 07 @ 1:49 am
yes you can download the vista update for mk2 from your download center ;)
geposted Tue 07 Aug 07 @ 1:52 am
but if i buy this cd, it looks like it wont install in the 1st place in my computer, let alone update it... do u see what i mean>?
i mean like how can i update it if i cant have the program installed in the 1st place?
geposted Tue 07 Aug 07 @ 5:01 am
You can download the full Vista VDJ 3.4 from this site.
It works a treat. And ignore the review on that page that says you can't lock out the jog wheels as I always disable mine
geposted Tue 07 Aug 07 @ 11:04 am
geposted Tue 07 Aug 07 @ 2:01 pm
it works now, thank you so much man....
geposted Tue 07 Aug 07 @ 2:33 pm
