Forum: Old versions
Topic: midi mapping VDJ console edition
hi,
I use the hercules MK2 and would like to change some midi mappings, is this possible in the VDJ edition you get when buying the console, if so, how?
grtz
geposted Thu 09 Aug 07 @ 7:06 pm
which you can do at a
discount as you own virtual dj home edition
ok, thanx
you can map in your version too.
Just disable the console in controller page, and enable midi instead
And manualy map the midi functons you want.
The pro version has pre made mappers that makes it a lot easier though, that you get access to with pro version ;)
