Forum: Old versions
Topic: Scratch wheels on bcd3000 working plus images
Here is a midi layout and how I use the scratch wheels on the bcd3000
geposted Thu 09 Aug 07 @ 8:30 pm
Caution Use at your own risk, Atomix Productions can't be responsible for the any problems that are due to the use of this file ie viruses spyware , ect and gives no support for any issues caused by downloading this file
You are right Skyfxl everything there is use at your own risk,
Just to be more clear the zip file contains:
A word Document called: BCD3000 instructions
Two Images called: Midi Layout.jpg
And an XML File Called: vdj DJ R.xml this file is the file supportted VDJ for midi
and is ONLY FOR MAC.
So far it has been working with not troubles
Gracias!
Skyfxl is there a way that you can try it or anybody from Atomix Productions i am sure some people will enjoy playing with this as much as I do...
Just a thought...
Gracias
If it works on the mac well, it should for PC too... it uses same midi inputs, and XML mapping
And your file is a XML mapping on midi inputs to VDJ
Do you won a BCD3000?
would be interested in hearing if it works well in that case... Lots where mad about BCD2000, but the BCD3000 is hopefully better :)
can u fix that link? I think you might have typed a number or letter wrong.
Thanks!
DJ RPG
...or can u please upload to megaupload or sendspace?
works great, thanks!
Posted Thu 09 Aug 07 @ 15:31:26
______________________________________________________________________________________________________________________________________________________________________________________________________________
dj-in-norway,
I bought it,it came with traktor le and another cd with different programs, it works great, I think its alot better than the bcd2000, it has some issues with VDJ but at the end everything was working but the leds.
Thanks for your help again!
