Did Anyone get around to making a mapper for this little box?
Was thinking of using it in a multi-instance setting at home.
1st instance with the DAC2
2nd instance with X-Session Pro.
I saw the old mapper for the X-Session v1. Is it the same for v2(pro?)
geposted Thu 09 Aug 07 @ 10:06 pm
the xsession doesnt need a mapper
that file is just a midi actions file
you can set your own actions for it by
midi mapping
if you need any more help , add me on msn admin@skyfxlrecords.com
midi mapping
geposted Thu 09 Aug 07 @ 10:13 pm
