Forum: Old versions
Topic: Advice On Numark Total Control Jog Dials
Hi all once again! Need some advice or a solution on the sensitive jog dials on the Numark Total Control.
I've noticed that if you accidently bump or slightly move the TC, the jog dials think that they are being moved and the song currently playing is affected by it because of their sensitivity (like a one second pause as if it thinks that you're about to scratch with them). Is there a way to have VDJ Pro/Cue toggle the jog dials on the TC on/off on demand when you want to use them so that doesn't happen?
I'm just asking this question because I've seen some DJ booth setups were the large speakers and subwoofers are really close and the vibrations cause everything to shake in the booth. Just a hypothetical situation I would like to bring up so I don't run into this issue when I'm doing a gig (or anyone else!)
Thanks guys!
geposted Thu 09 Aug 07 @ 11:36 pm
Push the scratch button in nudge mode :)
